NI TestStand
How to get test result by each step
I want to use c++ builder just use TS Engine to build a UI interface.
I create a sequence file and use call backs(SequenceFilePostResultListEntry) to call PostUIMessageEx method(Set activeXDataPara is Parameters.Result).
The question is how to get step result by UI side, like numeric test value, test staut("Done"/Pass"/"Fail") etc.
if (!Engine1->IsUIMessageQueueEmpty)
  UIMsg = Engine1->GetUIMessage();
  vMesCode = UIMsg->Event;
  if(vMesCode == 10001)
    sStringData = UIMsg->StringData; //return step name
    dNumericData = UIMsg->NumericData; //return 0
    //how to  analytic ActiveXData? type is IUnknow.
  UIMsg->Acknowledge();
Many thank
(3,528 Views)
Update stauts, I found some solution to get ActiveXData and analytic parameters.result.
PropertyObject ProObj = MyContext.AsPropertyObject();
PropertyObject ProObjResult = ProObj.GetPropertyObject("Parameters.Result",0);
The next question is how to get result by engine OnUIMessageEvent? Current is use timer loop.
Any ideas?
(3,508 Views)
