NI TestStand
How to get the UUT_results status from Test Stand
I would like to write the UUT_result of a batch report. The one that says "Passed", "Failed"...etc to an external file using Labview program. I am new to Test Stand and I don't how/where to get this variable from. Could anyone help?
(5,102 Views)
You can get the overall result for an entire sequence from the variable called RunState.SequenceFailed. This variable is a boolean, True for sequence failed, False for passed. You can create a Local string variable, call it Locals.UUT_Result and create a statement step to set the string: Locals.UUT_Result = RunState.SequenceFailed ? "Failed" : "Passed". If the boolean is true, Locals.UUT_Result will be set to "Failed", and vice versa. Hope this is what you want.
- tbob
Inventor of the WORM Global
(5,102 Views)
tbob,
Thanks for your prompt reply. I tried doing as above but it keeps on returning false i.e. "Passed" each time i run the test even if the test fails. Am i doing it correct.
(5,102 Views)
Please attach your code so that I can review it. Give details on what you are trying to do and what is not working.
- tbob
(5,102 Views)
This is the way to do it..
Thanks tbob!
(5,102 Views)
Hi Kumar,
The way tbob described it is correct. However, you may need to set the Pass / Fail source to "Step.Result.PassFail".
JLV
(5,102 Views)
