NI TestStand
How to get the variable value of a step (ex : Step.TS.Data) with C#?
I try hard but do not managed, I can't get the variable situaded inside a step?
I have created my sequence object then my step object (I can get the right name of this one)
but I didn't find in the help the method allowing to get any value of the step variables.
Any idea? Thank you
(3,260 Views)
You obtain a reference to your step as an PropertyObject.
Using this PropertyObject reference you can use the PropertObject.GetValString|GetValNumeric|GetValBoolean.
Hope this helps.
Regards
Ray Farmer
Regards
Ray Farmer
(3,250 Views)
thank you so much, I made
  stepPropertyObj = step.AsPropertyObject();
  id = stepPropertyObj.GetValString("TS.Id", 0);
It's worl well, thank you once again!
Jambon
(3,239 Views)
