NI TestStand
How to group data types?
How can I group my custom data type like IVI and LabVIEW types visible below?
Should I look for some hidden attributes?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(2,203 Views)
I'm crosslinking the idea exchange: https://forums.ni.com/t5/NI-TestStand-Idea-Exchange/Add-tree-structure-to-data-type-menu/idi-p/20163...
Idk what is going on here... The feature is clearly there for years, but in 2019 it was marked as Under Consideration???
Michał Bieńkowski
CLA, CTA, CPI
(2,102 Views)
Accepted by topic author bienieck
I figured that SeqEdit uses preinstalled (probably hardcoded) prefixes to group some built-in types. It will group types with names beginning with "LabVIEW" and "NI_Ivi" (perhaps there are others as well). IVI grouping works even if you don't have those steps installed.
It is currently impossible to create custom groups.
Michał Bieńkowski
CLA, CTA, CPI
(2,086 Views)
