NI TestStand
How to hide the labview window?
is there a way to hide the LabView Window showing "First Steps" etc. during the runtime of TestStand? I had an operator trying to close the window during testing with fatal consequences.
Christian
(3,782 Views)
Can you post a Image and some description about which window you have to close
AshwiN,
(3,781 Views)
Has your step got 'Show Front Panel' enabled in the Specify Step?
Regards
Ray Farmer
(3,779 Views)
It's the default LabView "First Steps"-Window. It starts, when I load a testsequence into TestStand which contains LabView Modules. It is confusing for the operator and looks like this:
kind regards,
Christian
(3,756 Views)
Accepted by topic author Exle
What TestStand version are you using with LabVIEW 2010?
Have you tried changing the LabVIEW Adaptor to use the RTE rather than the development system?
Regards
Ray Farmer
(3,750 Views)
Changing the adapter from "Development System" to "Runtime System" did the trick. Thanks.
regards,
Christian
(3,747 Views)
