NI TestStand
How to implement the "View report" button in PostBatch?
I've seen the NI example which opens a result window and each row has a "open report" button. Clicking on the button opens the report. How may I achieve the same in LabView?
I'm showing the results in a labview VI where Sequence context is send as a parameter.
(2,223 Views)
Thanks for your post.
Please may I ask what NI example you are referring to?
Is this forum question similar to your problem?
Solved: Can i open a existing report using a report generation toolkit - Discussion Forums - Nationa...
Cheers,
YD
(2,183 Views)
Accepted by topic author Heartbeat
Get the path:
Parameters.ModelPluginConfiguration.Plugins[0].PluginSpecific.RuntimeVariables.BatchReportFilePath
Parameters.ModelPluginConfiguration.Plugins[0].PluginSpecific.RuntimeVariables.PerSocket[%d].Path
Open the file externally using cmd.
(2,176 Views)
