NI TestStand
How to import variable amount of property values from Excel
I want to use Excel to save limit values for string variables used in numeric limit tests. String variables are predefined and amount of them is constant. The string variables may look like 4QAM, 16QAM, 64QAM, 256QAM etc. Corresponding limit value is numeric. I would like to perform one measurement in time and import limit value corresponding to string variable in numeric limit test. I don't measure all string variables every time. With other words, I want a flexibility to measure a value, compare it to limit value found in Excel for respective string variable.
What is the simplest way to do this ?
Petri Hyvärinen
(3,525 Views)
Hi Petri,
Just trying to understand your problem?
Are 4QAM, 16QAM.... the names of the string variables? Could you supply an example excel file to show what you are after.
You could try looking at my example in
Regards
Ray Farmer
(3,520 Views)
Here's one Excel example file.
Ray, I couldn't succeed to find your example.
/Petri
(3,512 Views)
Hi Petri,
Sorry about that link, dont know what happened there.
it should have been this.
Thanks for the excel file, it helps a lot.
Regards
Ray Farmer
Regards
Ray Farmer
(3,506 Views)
