NI TestStand
How to include a carriage return in a TestStand string variable
Is there anyway to add a carriage return to a TestStand string variable. I am sending commands to an instrument using the Rs232 serial bus and they need to be terminated with a carriage return ie "\r". I know you can creat a DLL and return the string variables to TestStand but is there a beter way ?
(9,236 Views)
Hi Paul,
Use an expression similar to this:
Locals.MyString =Locals.MyString +\\r
Replace Locals.MyString with your variable Lookup string.
You can put this expression in the PreExpression of your step.
Regards
Ray Farmer
Regards
Ray Farmer
(9,229 Views)
Hi Ray,
Many thanks for that but I don't seem to be able to get it to work. When I put
Locals.SIU_WRAP = Locals.SIU_WRAP+\\r
In my Pre Expression I get the following Error
Syntax error in pre expression:
Unexpected token: \
This value will cause a run-time error.
any idea
Regards Paul.
(9,222 Views)
Hi Paul,
Sorry about that, just noticed I left off the "" in my last response.
Try "\\r".  that should solve it.
Regards
Ray Farmer
Message Edited by Ray Farmer on 09-15-2005 09:14 AM
Regards
Ray Farmer
(9,218 Views)
Actually probably just "\r" (just one backslash). Depends on whether you want your string to contain the two characters backslash and 'r', or whether you want the actual carriage return character in your string.
-Doug
Message Edited by dug9000 on 09-15-2005 10:20 AM
(9,209 Views)
