NI TestStand
How to insert a local variable using the ActiveX/COM adapter?
In teststand II,
Develop a small sequence that programmatically inserts a locals variable using the activex/com adapter, the sequence context, and the Property Objict class?
(3,388 Views)
The steps needed to dynamically add a variable are covered by this KnowledgeBase article:
How Can I Programmatically Create Variables in TestStand?
Just change the lookupString to the local name you require, eg. "Locals.NewVariable"
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,360 Views)
The TestStand API can be called directly from expressions, so there is no need to use the ActiveX/COM adapter to call the TestStand API from a sequence.
Hope this helps,
-Doug
(3,349 Views)
I'd prefer to call it as an expression, but it looks like the homework question calls for an ActiveX step.
(3,344 Views)
Hi, Charlie Rodway
Thank you very much.
would you PLS aslo let me know how to call it as an expression?
(3,303 Views)
As an expression, you could use:
Locals.NewSubProperty("NewString1", PropValType_String, False, "", PropOption_InsertElement + PropOption_DoNothingIfExists)
You could also use the following expression if you want to set the value at the same time, eg "TEXT":
Locals.SetValString("NewString2", PropOption_InsertElement + PropOption_DoNothingIfExists, "TEXT")
I hope this helps,
(3,268 Views)
