NI TestStand
How to insert a new step type into a submenu?
Hi!
I'm inserting a step type into the MyTypes.ini file with c++.
With the code below I managed to put it into a menu (in the step type menu editor it is called "Group").
But I want a sub menu.
How can I put it into a sub menu (in c++)?
Who can help me? Thanks in advance!!!
Here is the code:
property->PutName("StepTypeName");
typeUseage->InsertType(property, 0, TS::TypeCategory_StepTypes);
stepObj->PutMenuGroupName("StepTypeMenuGroup");
(3,362 Views)
Hello TSNewbie,
I hope that this example will help you.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3D88556A4E034080020E74861&p_node=DZ52238&p_source=External
Best regards
TN
(3,362 Views)
Hello TN,
unfortunately it doesn't help me!
I wanted to know how I can add a group (a subgroup) to the "Step Type Menu Editor" of the "Type Palette" with a program written in C++.
(3,362 Views)
TSNewbie,
There is no API method to edit those groups. I can only suggest to use the Step Type Menu Editor to create the group you want and make it a submenu. Then when you call stepObj->PutMenuGroupName("SubMenuGroup") the step type will be in that submenu.
I apologize if this isn't the answer you are looking for.
Ronald Byrd (NI)
(3,362 Views)
Thank you!
Then I have to edit the "TestExec.ini" programmatically.
(3,362 Views)
