NI TestStand
How to make Application Distributor in TestStand
I had make sequence file which use LabVIEW standard adapter for different Actions. I want to Make Applicaiton Distributor (like exe, or llb file of LabVIEW)?
How could I make this?
(2,986 Views)
With the Sequence Editor running, Under the Tools menu, select the option 'Assemble Test VIs for Runtime Distribution...'
This will put all your top level VIs in a target directory and all the support VIs is a llb call SupportVI.llb.
Or if you have the application builder. you could try running the old distribution kit found in \labview\project\oldinstall.llb.
Hope this helps
Merry Christmas and a Happy New Year
Ray Farmer
Regards
Ray Farmer
(2,986 Views)
