NI TestStand
How to match regular expressions in TestStand
I found this: https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsref/regular-expressions.html
But what's the syntax for matching a string to a regular expression in TestStand? I checked the manual and couldn't find anything. I use TestStand 2017.
-Frank
(2,404 Views)
Hello FrankJensen
There are two articles, that can help you to understand how it works.
Here they are
Creating and Editing Expressions in TestStand - NI
Match a Sub-string with a Regular Expression in TestStand - NI
Also, can you elaborate further about what you trying to do?
Regards)
________
Best way to thank is giving Kudos/Marking as a solution
(2,217 Views)
