NI TestStand
How to open Sequence file of teststand 4.1 in previous version 4.0
hello,
Greeting s of the day.
Actully i have installed ts4.1 and then reinstall ts4.0 but the sequences i have modified in ts 4.1 written in 4.0  is not agian working  ts 4.0..
and i cant use ts 4.1 because i have whole set up in our lab with 4.0 and at many machines as i have checked in the file while after modifying with 4.1 other cant aable to open in 4.0.... please tell any workable solution immedatly as same .seq file is there.
thanks and regards
kulwant singh
(3,239 Views)
Have you saved as your TS4.1 file and selected TestStand version 4.0 SEQ in the drop down control.
Regards
Ray Farmer
Regards
Ray Farmer
(3,238 Views)
Hello Ray,
yes i have saved as 4.1.But now  their i found the solution of saving sequence as 4.0x also.
kulwant singh
(3,234 Views)
