NI TestStand
How to output the result of a Numeric Limit Test to Excel?
I would like to take the result of a Numeric Limit Test into Excel along with the test data (which I can do).  Any ideas welcome!
(3,469 Views)
Hi Lauda,
One important question before: Is it just one Step or is it the hole SequenceFile consisting of NumericLimit Test?
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,459 Views)
Juergen,
Thanks for the reply. Due to customer requirements, the test results are output to a pre-formatted Excel file.  The result numberes are not a problem, but I need to also record the results of each Numeric Limit Test I have found "ThisContext.Step.Result.Status" function and will try this - could this be the answer?
Thanks.
(3,456 Views)
Hi Lauda,
If you only want to filter a special StepTyps's report i would do this with the SequenceFilePostResultListEntry Callback.
Just look at the example.
If you need this feature in serveral SequenceFiles you should do this in the TS Model itself by changing the TestReport sequence.
hope this helps
Juergen
--Signature--
(3,449 Views)
