NI TestStand
How to pass data result from one sequence step to another.
I need to gather an offset voltage in one of my sequence steps. Another step later in the sequence uses this offset voltage to set a base level for more measurements. I need to pass the offset voltage to these later steps to create an offset base voltage to use in a formula to calculate a current gain in the positive and negative directions..
(3,804 Views)
Just pass the value to a local variable.
(3,787 Views)
... and also take a look to the "HelloWorld" example the Computer Motherboard Test Sequence.seq
you will find it in
ProgrammFolder\National Instruments\TestStand 4.0\Examples\Demo\LabVIEW\Computer Motherboard Test
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,778 Views)
Thanks for the replies. I should have mentioned that I don't have a text programming background and I should have given some more details. I know that I need to pass a local variable from one step to another. What I need to know is how to write the expression properly to pass this variable. When I tried it on my own I passed the offset variable numeric data from a numeric limit test step to a local variable. It passed the data to the local variable but it lost the numeric value for the step I was writing the expression for. This resulted in a "0" numeric value for my initial offset value step that fails this numeric limit test.
(3,748 Views)
Local variables just don't get 'lost'. Why don't you attach the sequence file and any code modules you are using?
(3,731 Views)
