NI TestStand
How to pass output data from sequence
Hi All,
I have a sequence that calls itself in certain condition and save output data cluster to local (its own thread). I can't figure out how to read this data cluster from other thread ( the caller of the sequence. I can't use global because this is running in batch model).
I appreciate the help in advance.
(3,183 Views)
I did some deeper research and found I needed to change How Passed to by reference. Thanks.
(3,173 Views)
Glad you were able to sort this out yourself.
Regards
Ray Farmer
(3,142 Views)
