NI TestStand
How to prevent teststand from crash if array index out of bounds for one of the test sockets
I have to test 20 UUTs using batch model.
I go to SQL server and read 20 serial numbers that  have to use in my tests.
I have to use 7 test sockets.
Each time I tun sequence, seven serial numbers are passed to the tests.
So...in first run of batch sequence, parts 1-6 are tested, in second run parts from 7 - 14 are tested.
The problem is when sequence runs for the third time, when parts from 15-20 are tested. Test socket number 6 does not have UUT to test since there are only 20 UUTs (serials) to test and no 21.
The test socket 6 error is presented : "Array Index out of bound".
Please help how to solve my problem
Message 1 of 1
(2,343 Views)
