08-23-2005 10:55 AM
08-23-2005 01:27 PM - edited 08-23-2005 01:27 PM
Message Edited by Antonio Lie (NI) on 08-23-2005 01:31 PM
Message Edited by Antonio Lie (NI) on 08-23-2005 01:30 PM
Caribe,
I. In order to accomplish this you need to insert a custom substep in your step type.
1. Go to your step types properties and select the substeps tab.
2. Select the ActiveX/COM Adapter from the Adapter list.
3. Add a new custom substep.
4. Rename it -> OnNewStep
5. Specify the Module.
6. Object Reference = Step.
6. Object Class = Step.
7. Call the Method -> EditCode.
Now every time you insert your step, this substep will be executed and as a result you will get the Express VI configuration dialog.
Best Regards.
Rename the
Message Edited by Antonio Lie (NI) on 08-23-2005 01:33 PM
08-29-2005 07:58 AM
Hello Antonio!
Many Thanks! This was exactly what I needed!
I wanted to send you a comment on this, but the message body text input was with some kind of bug last week, so that I coudnt reply the message 😞 Now its working! 🙂
I have some more question about ActivX substeps. Which oder substebs can I use to change the TestStand functionallity in order to fullfill my purposes?
For example, you mentioned the "OnNewStep" substep, but are there other substeps like "OnDoubleClick"? Do you have a list of activeX Step types that can be used?
Question: How do configure my custom Step Type to call its Express VI configuration Dialog box each time I double click the Step in the sequence editor?
I appretiate a lot your help! Its really amazing all we can do with Test Stand using custom Step Types!
- Caribe -
