NI TestStand
How to programatically close the sequence without saving the file? SaveOnClose not working!?
Hello
I have a sequence file open in TestStand. The sequence is modified and not saved so it contains changes. I'm trying to close it programmatically like in attached picture. I don't want to save the changes. I just want to ignore the changes, do not save and just close the file. To do that I'm trying to set the property "ApplicationManger->SaveOnClose" before calling method " ApplicationManger->CloseSequenceFile", but the property does not work. TestStand anyway shows the popup screen with question: "Do you want to save the file?"
Why does it not working and how to do that?
Thanks for any help
(3,030 Views)
You probably need to handle the QueryCloseSequenceFile event in order to avoid the popup.
CTA, CLA, MTFBWY
(3,016 Views)
yes, but it might be difficult.
I have one workaround now: I save the sequence to some temporary folder and then remove it from this folder. This way popup screen does not appear but i wonder why the property SaveOnClose does not work at all?
(3,014 Views)
