NI TestStand
How to programmatically read the SequenceFile currently open (front most) ?
@maszup wrote:
I used SequenceFiles (attached picture) to get all open sequence files from TS.
I will check the SelectedFile property in the meantime.
Thanks for your help
this solution will not work like i wished. it will show me the sequence file that was used to call the submenu from the teststand menu but it will not show me the sequence active in teststand
Message 11 of 13
(1,512 Views)
the solution that DowNow_ is working fine. I didn't know how to use it by TS API in LV because i was trying to pass somehow the "RunState" ref from TS to LV but in fact i can use that way:
thanks DowNow_ for help
Message 12 of 13
(1,506 Views)
Accepted by topic author maszup
Message 13 of 13
(1,506 Views)
