NI TestStand
How to read a particular software version installed
How to read a particular software version installed inside TestStand?
I wanted to read a particular tool version installed on the machine to log inside my test report.
(3,803 Views)
Do you pull this from the registry?  Add/Remove Programs?  Where can you get this info?
You can use additional results to log the actual version.  Or you can put in in the Report Text of a step.  Just depends on what you are going for exactly.
Does it impact the pass/fail status of the test?  If so then a String Value Test would probably be the best.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,792 Views)
I there any dos command which we can execute and read the result in TestStand?
(3,783 Views)
I am testing a tool which is installer. I wanted to run tests for this tool and wanted to log the version currently installed on the PC as an tool version I am executing tests for.
I got on dos command which can read the installed version. But I am not sure how I can read the command response in TestStand.
(3,782 Views)
Accepted by topic author joshisagarr
https://forums.ni.com/t5/Community-Documents/Display-and-execute-command-lines-from-within-a-TestSta...
Try this. It should get you pointed in the right direction.
Hope it helps,
jigg
CTA, CLA
testeract.com
(3,771 Views)
Here is the DOS command to read a particular version of the Software
wmic product where "Name like '%App Name%'" get Name, Version
(3,735 Views)
