NI TestStand
How to read expression as string through TS API
I'm writing a custom step type with labwindows cvi, and i parse all step with Numeric test in sequence (and subsequence recursively).
I have no problem to read Low and High properties when it is a constant numeric value (ie 9, 11, ... using TS_PropertyGetValNumber (caobjStep, &errorInfo, "Limits.High", 0, &lfHigh))
My problem is to read properties with expressions inside (ie FileGlobals.Limits.iValMax[Locals.iLoopIndex]) as string.
I have tried TS_PropertyGetValString, but error.
If anyone can help me...
(2,513 Views)
If you are doing this 'on the fly', you can use the function Evaluate to get the actual value contained by the variables.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(2,508 Views)
Thank you for your answer.
OK for the value. But how can i catch the string of the expression?
Is it possible?
(2,495 Views)
