NI TestStand
How to read test data from excel in test stand with out labview
Hi Team,
I have some test data in excel sheet which i need to use to test dotnet dll using test stand.
can you please inform me the possibility of storing data from excel into array of test stand.
I have seen Test stand examples for limits loading using property loader,but it is useful only for properties.
please guide me how to extract testdata from  excel into test stand variables(array) without using Labview
(3,787 Views)
You can use the property loader to retrieve data from a xls file into your TestStand variables.
The easiest way to set up an XLS file is to use the Import/Export tool in the Tools Menu and export your array to your file.
Then you can setup up your PropertyLoader step to load your array at runtime.
There are examples using the PropertyLoader to load variables on the website and in the TestStand Examples.
Regards
Ray Farmer
(3,784 Views)
The Property Loader section of Appendix C, Database Step Types, of the TestStand Reference Manual has some info about reading information from Excel files. Might be something worth checking.
http://www.ni.com/pdf/manuals/373435e.pdf
Tom
TestStand Documentation
(3,760 Views)
