NI TestStand
How to read the content of the ResultList in a C# code module?
public void LogUutData(Execution execution)
    PropertyObject propertyObjectResult = execution.ResultObject.GetPropertyObject("ResultList", PropertyOptions.PropOption_NoOptions);
    for (int intCounter = 0; intCounter < propertyObjectResult.GetNumElements(); intCounter++)
        object objResult = propertyObjectResult.GetValVariantByOffset(intCounter, PropertyOptions.PropOption_NoOptions);
       // How to read the content of objResult?
I suppose the methods used in the code snippet are correct.
How do I have to handle an object to read the content, the information about this issue in the help file is really limited.
Does anyone know how to do this, or are there better alternatives to iterate through the ResultList, any help will be highly appreciated.
Best regards
(3,861 Views)
Hi, I was able to iterate through the Results Container but have som more questions,
Delegate defined:
m_ApplicationMgr.StartExecution += new _ApplicationMgrEvents_StartExecutionEventHandler(OnApplicationMgr_StartExecution); void OnExecutionViewMgr_EndExecution(Execution execution){      PropertyObject propertyObjectExecution = execution.ResultObject;}
After execution ‘MainSequence’, event ‘OnExecutionViewMgr_EndExecution’ is fired
      ResultObject, Sub Property SequenceFile, is path statement for the current executed sequenceResultObject, Sub Property Sequence, is ‘MainSequence’ResultObject, Sub Property ResultList is a container with the results for logged steps. Question: This result container does not contain information about the limits, how to add the limits to the result container?
After execution ‘Execute SinglePass, event ‘OnExecutionViewMgr_EndExecution’ is fired
     ResultObject, Sub Property SequenceFile, is path statement for processmodel?ResultObject, Sub Property Sequence, is ‘Single Pass’ResultObject, Sub Property ResultList contains nothing? Question: How to make sure this ResultObject contains information about the current executed sequence, I do need information about the processmodel?
Any help will be highly appreciated
Best regards
(3,839 Views)
Better formatted this time... Hi, I was able to iterate through the Results Container but have som more questions; Delegate defined: m_ApplicationMgr.StartExecution += new _ApplicationMgrEvents_StartExecutionEventHandler(OnApplicationMgr_StartExecution); void OnExecutionViewMgr_EndExecution(Execution execution) { PropertyObject propertyObjectExecution = execution.ResultObject; } After execution ‘MainSequence’, event ‘OnExecutionViewMgr_EndExecution’ is fired ResultObject, Sub Property SequenceFile, is path statement for the current executed sequence ResultObject, Sub Property Sequence, is ‘MainSequence’ ResultObject, Sub Property ResultList is a container with the results for logged steps. Question1: This result container does not contain information about the limits, how to add the limits to the result container? After execution ‘Execute SinglePass, event ‘OnExecutionViewMgr_EndExecution’ is fired ResultObject, Sub Property SequenceFile, is path statement for processmodel? ResultObject, Sub Property Sequence, is ‘Single Pass’ ResultObject, Sub Property ResultList contains nothing? Question2: How to make sure this ResultObject contains information about the current executed sequence, I do need information about the processmodel? Any help will be highly appreciated Best regards
(3,836 Views)
Another try,
Delegate defined:
Best regards
(3,826 Views)
