NI TestStand
How to read the step-type of a custom step in LV
I have a simple custom step that's created by combining a step type with Numeric limit test. How can i read this teststand step type in LabView?
I can read the default teststand test types using the vi as in the attachment but if I use the same VI, it returns the name that is assigned for the custom step. Step type.JPG
(2,152 Views)
You almost get it 🙂 use the property Name of the StepType object.
(2,138 Views)
