NI TestStand
How to reenable interactive execution?
       I am using Test Stand 3.5 and LabWindows 8.1 for my test s/w development.  I am using customised full featured CVI operator interface for my tests. When a particular sequence file is loaded, I am able to select individulal tests by selecting "Run Selected Steps". When the execution is over, and again coming back to "Sequence Files" view, I am not able to select interactively.
     Could anybody tell what is the problem happening or how to resolve the problem?
Thanks in advance...
Best Regards,
Vijay
(3,559 Views)
It sounds like you haven't released the handles for the interactive execution, or maybe you have closed the handle for the sequence file.
Do you get any errors if you close the OI?
What sort of things have you done in you customised version of the OI?
Regards
Ray Farmer
Regards
Ray Farmer
(3,552 Views)
          I am not receiving any errors when I am closing application. If I am loading sequence file from "open sequence file" menu, I can do interactive execution again.
       I have customized by showing only sequence file view and execution view and I am not displaying report view for my OI. Also I have discarded use of Layout function. I have attached my source code with this.
Any help to resolve the problem would be highly appreciated.
Best Regards,
Vijay
(3,530 Views)
Hi Vijay,
I'd like you to try doing this on the original CVI operator interface. If it works, then you will have to troubleshoot the code as you might have changed more functions than yothink you have and if it doesn't work then this can be filed for a corrective action.
Thank you,
Warm regards,
Arjun Khullar
(3,515 Views)
