NI TestStand
How to run from the caller's step in teststand
When an error occurs in a step during a sequence, I can use the SequenceFilePostStepRuntimeError call back to catch the error. But how can I go back to the step which is the one just raised the error for a retry run again? I do not want to make all test fail straightway, but want to go back to the caller step to have retry a few times 1st.
Many thanks,
WeiL
(3,298 Views)
Accepted by topic author WeiL
There is an example which shows how to do exactly what you are asking located at:
<TestStand Public>\Examples\Callbacks\PostStepRuntimeErrorCallback\ErrorHandlerExample.seq
Hope this helps,
-Doug
(3,284 Views)
Thank you very much, it works!
WeiL
(3,271 Views)
