NI TestStand
How to save the test report file which is saved with .xml at Excel 2016?
I'm using NI TestStand 2014 and I saved a test result with ATML 5.00 standards report.
When I use Excel 2010 , I could open the file without any limitation, however after upgrade to Excel 2016 it's opened with protected view and I can't edit and save.
Have you experienced this kind of problem with Excel 2016?
There's no problem to open the file at Excel 2016 because I already modified registry according to NI forum.
(2,671 Views)
did you change your Protected View settings?
https://support.smartvault.com/Other/Knowledge_Base_and_Known_Issues/Turn_off_Protected_View_in_Exce...
Cheers,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,656 Views)
Hi, jiggawax
I turned off Protected view, however it opened with Protected view again.
I tried to refer to your recommended link but it's blocked by company's security wall.
Finally I found another solution to resolve this problem that I can set the folder which has the test report files as a 'Trusted Location' in Trust center of Excel.
jiggawax, Thank you so much for helping me. I could have a clue from your answer and it was a starting point!
(2,648 Views)
