NI TestStand
How to see changes in my ini-file of Types palette
I added new .ini file into Types palette. When I am exiting from Teststand it asks me to save modified ini-files. How can I see what changes are made to this ini file? Now I see only *mark before my ini-file in Types palette but can't see what are the changes.
BR,
Jick
Message 1 of 8
(4,382 Views)
To compare the TypePalette-files,
you can use the FileDifferLauncher.exe that comes with TestStand
Hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 2 of 8
(4,381 Views)
I use TS 4.0 and TS 4.2.1. TS 4.0 does not have such exe and TS4.2.1 can compare only sequences not ini-files?
Jick
Message 3 of 8
(4,377 Views)
Hi ,
Please try this link
NI TestStand Toolkit for Large Application Development
https://decibel.ni.com/content/docs/DOC-4070
I don't know if it is working with .ini files - just try
Regards
Juergen
--Signature--
Message 4 of 8
(4,374 Views)
You can also change the format of the file using the station options, file options dialog to xml, which should be a bit more diffable in text based differ.
-Doug
Message 5 of 8
(4,367 Views)
If I add my own ini-file to Types palette *mark appears after the name. When I close TS it asks me to save it althougt I have not done any changes. Why?
BR,
Jick
Message 6 of 8
(4,352 Views)
Hi Jick,
I think you have enabled the automatic Type Conflict Resolution on your maschine.
Configure->StationOptions->File->Allow Automatic Ty...... -> Set to "Never"
After restarting TS again and adding your type-file a conflict-message should appear.
Read the conflict's reason.
Hope this helps
Juergen
--Signature--
Message 7 of 8
(4,350 Views)
BR,
Jick
It's either because of type conflict resolution (i.e. newer versions of types are already in memory that are contained in your file), or it could be because your file is from an earlier version of teststand and thus required conversions in order to bring it up to date. There is a setting in newer versions of teststand to customize the "marking as modified" behavior. In the Station Options->File tab, there is a setting, "Do Not Mark Files as Modified if Modification is Caused Only by Automatic TestStand Version Upgrade", which you might be interested in using.
Hope this helps,
-Doug
Message 8 of 8
(4,335 Views)
