NI TestStand
How to send data to labview code at run time while using with (or executing the sequence)the teststand
Hello
I am new to the Teststand.
I am using labview8.0 with teststand 3.1
I have developed some labview codemodules as vi's without using the teststand utility library pallete
Now i have to run them in teststand.
While executing them(as a sequence) in teststand,i need to enter the data to the labview code at run time.For this labview front panel should appear as GUI or popup (while executing).Is it possible to do this without using teststand pallete.
or i need to change the code with teststand pallete(i think it is difficult now to change the code)
Plz provide a solution to this problem
Also one more,how and where to use the 'pass by reference' option
Thanks and Regards
  Mudigondla
(2,895 Views)
see your other post http://forums.ni.com/ni/board/message?board.id=330&message.id=13914
Also, you can, specify to display the front panel of your VI when you specify your VI in your sequence file.
There are examples, for dialog panel using LabVIEW, in the examples folder of TestStand and on the NI Web Site.
Regards
Ray Farmer
Regards
Ray Farmer
(2,886 Views)
