01-19-2010 01:05 PM
I want to set a hard coded value in my sequence in NI TestStand.
How will I set a value for 2-dim string array in NI TestStand Sequence Editor without creating local object?
01-20-2010 05:33 PM
Hi mbda,
It is possible to hard code a 1 dimensional array , using thefollowing syntax:
myArray = {"a","bb","ccc"}
to do this with a 2d array,we'll need to first create a 1d array, then reshape it as a 2d:
myArray = {"a","bb","ccc","d","ee,"fff","g","hh","iii"},
SetArrayBounds(myArray,"[0][0]","[2][2]")
Let me know if you have any trouble getting this to work!
01-22-2010 11:19 AM
Thanks AI B.
I was talking about in the NI TestStand Editor itself... but somehow you gave me an idea with your answer.
Its the bracket string --> {"Sample", Str(Locals.myCollection[RunState.LoopIndex])}
02-01-2010 02:59 PM - edited 02-01-2010 03:06 PM
I thought I got it right but its throwing me an error that the "The dimensions for the array '{"['Temp', Str(Locals.twoDimCollection[RunState.LoopIndex])]"}' do not match
the dimensions needed for the parameter 'inputParameter'."
My challenge is from my .net dll, I have a method that is asking for 2-dim parameter. Example: MyMethod(string[,] paramA)
From the NI TestStand editor, how can I passed a hardcoded 2-dim array? If it is 1-dim array, I dont have problem setting values because you can click plus(+) sign from the editor to add values and/or elements but when it is 2-dim there is no such icon.
I am pretty sure this question has been raised before it seems I cannot find solution to my problem.
Can anyone help?
Thanks!
