NI TestStand
How to set dotnet enum function parameter with statement?
i have a custom function written in c# that offers the parameters with enums. So i get a dropdown-list where i can select the valid-parameters.
How can i set this parameter with a statement?
It looks like that i can pass the numeric enum OR the corresponding string of the needed enum.
But is there also a way to get/see the all valid enum-values in the statement?
Thx
(3,270 Views)
Hi!
as far as I can see the same question has been posted and answered before. Does that discussion help you along?:
Solved: .Net enums - Discussion Forums - National Instruments
http://forums.ni.com/t5/NI-TestStand/Net-enums/m-p/1950055
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(3,177 Views)
