NI TestStand
How to set up Labview controls/indicators so the TestStand will automatically import them
I am pretty new to Labview and TestStand.
I have created a simple Labview GUI with controls and indicators. When I add the labview module to TestStand it does not import these controls/indicators.
What do I need to do to get TestStand to import these controls/indicators.
Thanks & Regards,
Doneen.
(3,055 Views)
Accepted by topic author Doneen
Is this just a LabVIEW VI set up as a step in TestStand? If so did you wire up the controls and indicators to the connector pane in the upper right hand corner of the LabVIEW vi? (hint right click the icon and select show connector pane)
Is this a LabVIEW implimentation of a TestStand Operator Interface? If so look at the examples in TestStand folder for Simple LabVIEW Operator Interface.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,049 Views)
