NI TestStand
How to setting VI repeat one times only with judgemnt result is fail in first time
Hi everyone,
I think for a long time without best solution. I need help to get some advice.
Here is the thing, I create the 3 vi in my teststand sequence.. My module item is unstable to fail the first time. That’s why I want to make a retest current vi could like this flow chart. I try to process with Test Stand post-action to help solve. The function could be available to solve pass and fail judgement but it had one problem once my module had a real fail, running the post-action function would become an infinite loop. I need a consultation to solve this in another way.
(678 Views)
You could use the looping action
(646 Views)
