NI TestStand
How to setup a new system using only "Base Deployment" licence
on my development computer with "TestStand Development System" i created a teststand-sequence.
The sequence is called in a custom operatorinterface using the Teststand API.
Now i have a second PC where i only want to activate the "Base Deployment" licence and execute the sequence in my custom operatorinterface.
But: How can i configure here teststand for things like:
-StationGlobals
-SearchPath
-Model options
-Station options
-Result folder
Or is the only way doing this by manually copying the CFG-directory?
Or do i have to activate at the beginning a development-licence for setting up everything and changing it to base when everything is running?
(1,774 Views)
Could you add that folder to your deployment or a test stand workspace?
(1,736 Views)
Hello Onlyone,
Probably this article Transferring Configuration Files to a New Version of TestStand should help you to perform this.
Also, review this one: Solved: Location of StationGlobals variables - NI Community
But if it doesn't help, you should have done it manually.
Best Regards.
(1,688 Views)
