NI TestStand
How to specify elements of boolean array
I'm quite frustrated as I fail to accomplish a rather simple task....
I specified an array of booleans as a parameter in one sequence file.
I call this sequence from my mainSequence and need to specify values to this array.
How do you specify values into this array..... False, True, True.....etc..
I failed anything I tried.  I search through the help and documentations but nothing.....please help
Rafi
(3,341 Views)
Hi Rafi.
Here is an example of an array constant you can use as an expression to pass it to your sequence:  { False, True, True }
Hope this helps, Guenter
(3,337 Views)
