03-11-2008 09:51 PM
03-12-2008 04:22 AM
Hi Paulbin
i took a look into the source code of the steptype CallExecutable (C:\Programme\National Instruments\TestStand 4.0\Components\NI\StepTypes\CallExec\callexec.c).
If you select in the step settings at Wait Condition other than "No Wait" and set Flag Terminate Executeable if step is terminated ... to true. Then your executable
03-12-2008 04:22 AM
Hi Paulbin
If you select in the step settings at Wait Condition other than "No Wait" and set Flag Terminate Executeable if step is terminated ... to true. Then your executable will
03-12-2008 04:22 AM
Hi Paulbin
If you select in the step settings at Wait Condition other than "No Wait" and set Flag Terminate Executeable if step is terminated ... to true. Then your executable will be
03-12-2008 04:33 AM - edited 03-12-2008 04:35 AM
03-12-2008 07:41 PM
Hi Juergen
I can not find the flag "Terminate Executable " in TestStand3.1, the application called is a long process application for firmware download to a UUT, it will not be terminated by itself, so I would like to force it close at other place in sequence.
03-13-2008 03:46 AM
03-13-2008 07:56 AM
