NI TestStand
How to to store data of three batches in teststand
Hello All,
Suppose you have a sequence with 3 batches (3 UUTs), and you want to store data of a specific variable when the 3 batches have finished
For example :
FileGlobals.OutputData contains different values from each Batch.
How can I Store this data in 3 different variables only when all the 3 batches have finished
DataBatch_1 = FileGlobals.OutputData (from Batch1)
DataBatch_2 = FileGlobals.OutputData (from Batch2)
DataBatch_3 = FileGlobals.OutputData (from Batch3)
Thanks for your help 🙂
(1,911 Views)
So no matter if  you are using batches or single UUTs: each testrun has it's own execution, so if you want to pass data from previous to future executions you have to use persistent variables like station globals.
(1,885 Views)
thank you for your response i will try this
(1,874 Views)
