NI TestStand
How to transfer values of local variables from TestStand 2.0 in CVI module?
What kind of adapters type should I use to pass Locals var from TS2.0 to CVI function? Any examples?
(2,870 Views)
Use the C/CVI Standard Prototype Adapter.
Inside your code module you would use an TestStand API call to obtain the value from your Local variable.
e.g.
// tsErrChk (TS_PropertyGetValString(testData->seqContextCVI, &errorInfo,
// "Locals.MyName",
// 0, &UserName));
This obtains the string value from the Locals.MyName variable.
Look at the example \TestStand\Examples\Demo\C\computer.seq for starters.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(2,870 Views)
