NI TestStand
How to trigger event in LabView VI from TestStand?
I have a LabView VI with an event structure. An event is triggered when either Button 1 or Button 2 is pressed. How do I program NI TestStand to trigger the same event in the VI ?
(1,393 Views)
Use Value Signalling Property node and write value to the respective control, which will generate an event without UI Actions.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,347 Views)
That works! Thanks.
(1,337 Views)
