NI TestStand
How to use Matlab with TestStand?
Do you absolutely need the Matlab API to do this?
If so, any hints on how to proceed?
RayR
(6,728 Views)
Hey Ray,
You would need to use the Matlab API to communicate from TestStand directly.  Judging by your name (JoeLabVIEW), however, I would like to point out that you could call a LabVIEW module that contains a MathScript structure (in which you could place Matlab-similar code).
Andy McRorie
NI R&D
(6,709 Views)
Thanks Andrew,
Using the Matlab API is what I suspected.  The client does not use LV, which is the reason for the question.
Yes, my nick can be misleading at times... 😉
RayR
(6,703 Views)
Hi JLV,
It maybe worth speaking direct to Mathworks as there appears to be several options you could take.
http://www.mathworks.com/access/helpdesk/help/techdoc/matlab_external/
Regards
Ray Farmer
Regards
Ray Farmer
(6,688 Views)
