NI TestStand
How to use MultiNumericLimitcheck for custom c#-teststep
i have a c#-teststep that has two returnvalues that i want to limitcheck.
Currently i put them into Step.Result.Measurement[0].Data and
Currently i put them into Step.Result.Measurement[1].Data
But what to do then? How can i add a limitcheck?
Thanks for help
(4,400 Views)
Accepted by topic author OnlyOne
For MultiNumericLimit test step type you should put them in Step.NumericArray[0] and [1] respectively.
Then on the Limits tab of the step you can add measurements (2 in your case).  Each measurement is comparable to a single numeric limit test type.  So you give it The Measurement Name and then set up the limits just like in a numeric limit in pane on the right hand side.
Hope this helps.  Let me know if you have more questions.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,391 Views)
Thanks. Its working now.
Is it possible to limitcheck only one value in a MultiNumeric-Step?
Currently i check [0] a [1]. If i decide one day that i only want to check [1]. Is this possible?
Thx
(4,373 Views)
I think it would be an intriguing idea to have each limit for the MNL have a flag to turn it on or off.  I like it.  You can post it on the idea exchange.
As a workaround you could do the following in your preexpression:
RemoveElements(Step.Result.Measurement, "[0]", 1),
Step.ExpectedNumMeas--
Looks like that is working.
jigg
CTA, CLA
testeract.com
(4,361 Views)
