NI TestStand
How to use different switchpositions in batch-model
i have a batchmodel that executes a testplan with 4 batches.
How can i use different switch-positions (NI SwitchExec) for each batch?
Is there a variable that i can readout that returns the current batch-number so that i can use a simple "if"
if (x.batchnr ==1)
     locals.switch = "POS1"
else if (x.batchnr ==2)
     locals.switch = "POS2"
else if (x.batchnr ==3)
     locals.switch = "POS3"
else if (x.batchnr ==4)
    locals.switch = "POS4"
and then use locals.switch as exepression in "Routes to connect".
Or how is this typically done?
Thx & BR
TM
(3,954 Views)
Accepted by topic author OnlyOne
Solved:
Simply had to put everything in a subsequence and set StepProperty "Synchronisation" to Serial.
(3,948 Views)
The current Batchnumber is stored in: RunState.TestSockets.MyIndex
(3,938 Views)
