Aleksi,
No problem, either launch your front panel vi via VIServer setting to return without waiting
or
pop your step in a Sequence, then you can run the step as a SequenceCall as a New Execution. Then before you can finish your execution by Killing the New Execution.
Or better still use your notifier to close your Front Panel.
(Note: I thought in TS3.0 you could now call a Step in a New Execution without requiring it in SequenceCall. Mayby I am confusing myself with running a LabVIEW Adapter in the runtime engine.)
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
