NI TestStand
How to use the LABVIEW button control to replace the Teststand Entry point 1 button?
Hi,all
In the Teststand default Simple UI software, we use the Entry point 1 Button to excute the teststand engine and start the UUT test. The Entry point 1 button is a teststand default button control, after it regists the sequenceFileviewmgr connectcommand, then it has the start test function.
From my side, I prefer to use Labview button rather than teststand default button to excute start function,Because labview button can be DIY. So the big problem is that I don`t know how to regist the labview button to the teststand engine that can control the teststand excution.
Thank you in advance!
Open28
(2,289 Views)
One approach is in the example here:
%TestStandPublic% or %TestStandPublic64%\Examples\Modifying User Interfaces\Building a TestStand UI with Native Controls\LabVIEW
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(2,254 Views)
Hi,weaver
Thank you for your rensponse.
It is what i want.
Thank you again.
Open28
(2,242 Views)
