I need to get in Labview some variables from Teststand. The VI I wrote use "Get Property Value" from Teststand and works fine... when I specify the type of variable I whant from Teststand (Boolean, I32,...).
But I need a VI which retrieve the value of my variable independently of the variable type.
I tried to set the type option "Automatic" but the "Get Property Value" always give back an empty array of boolean....
How works the "Automatic" option by the "Get Property Value"?
Is there a possibility in Labview to get the type of a Teststand variable?
Cheers,
Risotto
