NI TestStand
Howto get result of the calling-step in SequenceFilePostStepFailure
i have a sequence with a SequenceFileCallback "SequenceFilePostStepFailure".
How can i create a popup that displays the following values:
- Name of calling-step
- sequence-name of calling step
- result of calling step
- limit (low, high, string) of calling step
I found:
RunState.Caller.Step.Name,
RunState.Caller.Sequence.Name
but nothing for result and limits.
Thanks for any help
(3,932 Views)
You sould take a look to the parameters that comes with this callback
Just try this example
Note: This example is only working on NumericLimitTest!
Hope this helps
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,921 Views)
This should handle what you're looking for and then some. I use this with the retry expression that allows for the whole sequence to be repeated. Probably shouldn't allow for the "Force Pass". I think it origianally came from TestStand examples and I modified it, but I couldn't tell you which example.
Why do geeks think Halloween and Christmas occur on the same day?
Because 31oct = 25dec!
(3,864 Views)
By the way, the original callback was taken from the teststand example FailureHandlerExample.seq
(3,861 Views)
