NI TestStand
I/O Assistant
Good day all,
I need your help. I have a faulhaber motor MCDC3006S which works with a driver from Micromo. I have downloaded their examples. But anytime I run this, my motor does not run. Can anyone suggest to me what I am not doing right. Attached is the example I am running. The run button does not shows a broken arrow, so I usually expect that my motor would move when I click run, this does not happens.
Secondly, with the driver I have described above, anytime I go to Instrument I/O assistant, I can usually call some of the codes from the manufacturer and the motor would respond. Please like what DAQ assistant does, where you can call some actions and at the end of the day convert it to Vi block can I convert my actions in Instrument I/O assistant also to block diagram in Vi after adding steps.
(2,711 Views)
This doesn't sound like a TestStand question try posting
here
or
here
Regards
Ray Farmer
(2,707 Views)
