NI TestStand
I cannot open configure -> model options menu
Hello all
I am new to Test Stand.
For some odd reason when I try to open the configure -> model options.
I get the message shown in the attached screen shot.
After pressing "Ok" with or without the check box.  nothing happens.
What can I do.
Thanks!
Gil,
Message 1 of 8
(2,226 Views)
Hi Gil,
That is the model options dialog that is shown for the Sequential process model. If you want to configure the model options for the Batch model, you will need to either change the process model for Station or for the sequence file.
Anand Jain
NI
Message 2 of 8
(2,218 Views)
How Do I change the process model, I cannot access the menu option..
Message 3 of 8
(2,210 Views)
Anyone?
Message 4 of 8
(2,180 Views)
Can you please explain as to what you want to acheive.
Ravi
Message 5 of 8
(2,177 Views)
Hello Ravi.
I am trying to change beck the sequence setting. and change the number of threads or the operation mode.
Right now, I cannot change it.
Thanks!
Message 6 of 8
(2,173 Views)
Accepted by topic author gilmaor1
Can you post a screenshot of the UI that you are using? Is it the default shipping NI User Interface or something custom?
In the User Interface do you have a menu called Configure->Station Options?
That menu option should pull up a dialog shown below. In that dialog in the Model tab you can change the model used for the station to Batch process model.
Once the station model is set to batch, configure model options should allow you to change the number of settings for the batch.
Hope this helps.
-Anand
Message 7 of 8
(2,167 Views)
Thanks!
That solved the issue.
Gil,
Message 8 of 8
(2,148 Views)
