NI TestStand
I don't have Operator Interfaces with TS3.0 Installation
HI,
After the Installation of TS 3.0 I don't have a NI directory under \TestStand\OperatorInterfaces. I do have a User directory with some of my own interfaces.
How can I install them?
I found on the installation disk: \componnents\operatorInterfaces\OIPart.msi. I executed it, It made an installation, but still I can't see the desired directory.
Please help!
Rafi
(3,079 Views)
Ooops...sorry, false alarm.
I was looking for it in the directory where TS2.0 was istalled (c:\TestStatnd). I just found that TS 3.0 is installed under ProgramFiles.
By the way, I uninstalled TS 2.0 but still, the directory where it sat is still full of files.
Any recommandation how to to do a better uninstall to TS 2.0 (TS 3.0 is already installed!!)
Rafi
(3,079 Views)
Rafi -
TestStand as well as other NI products try to be very careful and only uninstall the files that were created by the installer and not any files that are created by the end-user after installation. Even though you would like some or manu of these to be removed, many customers do not like non-original files to be removed. For example, any files in the User directories or the Cfg directories should be left alone. I know that some of the TestStand installers before 3.0 incorrectly remove the \OperatorInterfaces\User directory.
Your only option is to just manually delete the contents under the installation directory if that is what you want to occur.
Scott Richardson (NI)
Scott Richardson
https://testeract.com
(3,079 Views)
